Activity › Forums › Adobe After Effects Expressions › Slider speed control
  • Slider speed control
    Posted by Konstantin Davidenko on June 3, 2012 at 11:43 pm
    Hello!
    I have an question:
    I have an object, which I need to move along one straight line but with different speeds (how world in Super Mario game moves, for example). How can I make slider, which will control the speed of object, but not it position?
    Thank you in advise.
    Konstantin Davidenko replied 14 years, 3 months ago 2 Members · 3 Replies
  • Dan Ebberts
    June 4, 2012 at 12:18 am
    It will be easier to have the slider represent an offset in the x direction, and have your position expression look like this:
    xOffset = effect(“Slider Control”)(“Slider”);
    value + [xOffset,0]
    Then control the speed by the keyframing the total x offset with the slider.
    Dan
  • Konstantin Davidenko
    June 5, 2012 at 1:40 am
    Sorry, or I don’t understand, how it should work, or it is not work properly =(
    June 5, 2012 at 1:22 pm
    I found the solution. It’s here: https://forums.creativecow.net/thread/227/15551#15559
    Dan, thanks for response.
