Activity › Forums › Adobe After Effects Expressions › Slider should only controll the x direction
  • Slider should only controll the x direction
    Posted by Pilsner Kanter on December 1, 2012 at 6:58 am
    i have 2 layers –
    one with Expression Slider – and one with a solid with a Split Effect attached.
    I want a slider to control my Split Effect.
    The split Effect is placed under Effects >Distort > Split
    With the expression slider I can control the Split point allright.
    But when i pickwic the slider to Point A – the slider controls
    both the x and y direction.
    What i want is the slider to control only the x direction. The y direction should not move at all.
    How to do that?
    Would be nice if there is a solution – so i can reuse it with other effects that are not
    expression friendly.
    Ashish Gupta replied 13 years, 10 months ago 2 Members · 3 Replies
  • Ashish Gupta
    December 1, 2012 at 9:15 am
    You can easily do this by using a keyword value in the expression.
    temp = thisComp.layer("Null 1").effect("Slider Control")("Slider");
    [temp, value[1]]
    or
    u can also assign a static number to y value
    x = thisComp.layer("Null 1").effect("Slider Control")("Slider");
    y=40;
    [x,y];
  • Pilsner Kanter
    December 2, 2012 at 12:48 pm
    Thanks for your solutions Ashish. Unfortunately I am not good enoughf with expressions to make
    use of the eksamples.
    Because what I really wanted as an end result is to be able to use the Split 2 Effect
    as a mouth with Lipsync. I want to use the Split 2 Effect to make a talking mouth.
    But as an intermediate step (before using a soundfile) I want to use an Expression Slider :
    1 Layer with Expression Slider that is used to control the 2 Split options.
    The hight of the Mouth – as when you say Ooohhh – you open up the mouth in y direction (i dont need help with this Layer. I can get it to work with just Pickwicking it to the Expression Slider.
    Now – on a second Layer I want another Expression Slider that control the With of the mouth – as when you are smiling – the mouth is wide but not high like when you say Ooohhh.
    My problem is with the second Layer. I want Point A to move at the same time as Point B – but the points should move either away from each other or nearer each other – depending on whatever I pull the Expression Slider to the left side or to the right side. Like a real mouth would move when talking.
    Can this be done with Expressions?
    The problem is that at the moment Point A and Point B moves in the same direction when I just Pickwic them to the Expression Slider .
    Maybee someone can come up with a better idea to utilize the Split 2 Effect to make a talking mouth.
    I know of the other different methods to make mouth Lipsync – but really I want to first see how far I can come with using Expressions and the Split 2 Effect as it give some other nice possibilities.
  • Ashish Gupta
    December 2, 2012 at 5:24 pm
    I think This should solve your problem..
    Use this for point A :
    x= value[0] - thisComp.layer("Null 2").effect("Slider Control")("Slider");
    y = value[1];
    [x,y]
    And this for point B :
    x= value[0] + thisComp.layer("Null 2").effect("Slider Control")("Slider");
    y = value[1];
    [x,y]
