Activity Forums Adobe After Effects Slider Controls
  • Slider Controls
    Posted by Max Baxter on April 8, 2014 at 6:12 pm
    Hi, I don’t know if this in the right area of of the forum for after effects, but this is also getting posted into other ones.
    I want to take multiple PSD files into after effects and then use a slider control to go through them all? for example at the start of the slider it is one image and then each whole number is a different image? (I know how to make the number rounded up so that’s not a problem it’s just the images part I’m struggling with.
    Any help will be useful
    John Cuevas replied 12 years, 5 months ago 2 Members · 1 Reply
  • John Cuevas
    April 8, 2014 at 7:54 pm
    Add a Null to your comp, add a slider to it and add the expression(you said you knew this, but just posting for those that don’t): Math.floor(effect("Slider Control")("Slider"))
    Open up one the opacity of one of your pictures and add this expression: mySlider = thisComp.layer("Control").effect("Slider Control")("Slider");
    if (mySlider == thisLayer.index-1)(100) else (0)
    Just using and If else statement that says, if the slider is Equal to and only equal to the index number of this layer(the -1 is because the layer 1 is the controller), make the opacity 100, else the it’s 0
    Just in case I missed something, here’s an example project: 7336_pictureslider.aep.zip
    Johnny Cuevas, Editor
    Thinkck.com
    “I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work.”
    —THOMAS EDISON on inventing the light bulb.
