Activity › Forums › Adobe After Effects Expressions › Slider Control of multible compositions
  • Slider Control of multible compositions
    Posted by Johan Nordström on September 14, 2011 at 2:34 pm
    Hi!
    Expressions and I are not very good friends, not yet. 🙂
    just so you know 😀
    So to the problem.
    I need to control several compostions(with different animated content)following a path defined by an other composition. and i need to offset them.
    Inside “Comp_A”
    a solid animated in 3D space.
    Inside comps: “contentComp1” “contentComp2″…
    are video clips.
    i want to control “comp_A” with a slider to move forward in time, and then stop for a bit and the move forward in time again.
    and the several other comps “content1” “content2”.. and so on.. I want them to be linked to move exactly like “comp_A”
    in the exact path, but with an offset.
    when i animate “comp_A” to stop i still want the video inside the “content1”-comp to be running.
    I have looked around the forum, but i have not found any answers to my problem. please link me if you find something 🙂
    Best regards
    /Johan
    Johan Nordström replied 15 years ago 1 Member · 1 Reply
