Activity Forums Maxon Cinema 4D Slice one object using another object
  • Adam Trachtenberg
    December 21, 2014 at 5:37 pm
    You can get that effect by using two Booleans of the same objects: one set to A intersect B and the other set to A without B.
    Example: 8316_booles2x.c4d.zip
  • David Hall
    December 21, 2014 at 10:28 pm
    Thanks Adam. That is not exactly what I was looking for, I was looking to “chop the cube” not the text. But the ideas is correct. And that is a clever way to do it. So thank you much.
    Now if I use that method, then I do end up with “inside geometry” correct?
    So either I would need to clean the inside of the object up and then optimize, if I wanted to say use a subdivision surface on this geometry later. Or I would be left wit extra geometry on the inside.
