Activity Forums Maxon Cinema 4D Sky object removes background
  • Sky object removes background
    Posted by Kelly Johnson on March 26, 2010 at 8:55 pm
    I am doing some camera mapping in cinema 4d. I have my tiff sequence in a material on my background. I have one 3d word in the scene and I want the scene to be illuminated using the sky object. When I add the sky object the scene disappears except for the text and the plane for the shadow. Your thought?
    Adam Trachtenberg replied 16 years, 5 months ago 2 Members · 2 Replies
  • Kelly Johnson
    March 26, 2010 at 10:10 pm
    So to fix this problem I actually added two more planes to my scene and gave them the same material with my image sequence and composite tag. I don’t understand but it worked.
  • Adam Trachtenberg
    March 27, 2010 at 6:09 pm
    I’m assuming you’re using the sky from the Objects>create sky menu and not the objects>scene>sky object. If so, all you have to do is turn off “sky” in the sky object’s basic tab.
