Activity Forums Adobe Photoshop skid marks
  • skid marks
    Posted by Bender on November 28, 2005 at 2:23 am
    hi
    i created some skid marks in photoshop….the view would be from above…no i want to add the skid marks into picture with a winding road…is there a way to bend the skid marks so the would fit a curve in road (the skidmarks i created a straight)…like drawing a path and use that as a reference for the skid marks…any ideas?
    thanks so much
    florian
    Bender replied 20 years, 9 months ago 3 Members · 3 Replies
  • Renato
    November 28, 2005 at 5:28 pm
    if you have cs2, you can try to use transform > warp and just bend the marks to fit the road…might not be the best way to achieve what you want, but until someone else posts a better solution it might be worth a try..
    good luck
    renato
  • Kim Mackenzie
    November 28, 2005 at 5:32 pm
    Filter > Distort > Shear will also do the trick. Although it’s frustrating, because you don’t have a lot of control, and the preview doesn’t show how the layer you’re distorting looks with relation to the layers below it.
    k
  • Bender
    November 28, 2005 at 6:33 pm
    thanks very much!
