Activity › Forums › Maxon Cinema 4D › Sketch & Toon Outlines Only Show Up On 1St Mograph Cloner Clones
  • Sketch & Toon Outlines Only Show Up On 1St Mograph Cloner Clones
    Posted by Jay Ingles on July 5, 2012 at 1:18 pm
    I’m using sketch and toon on a mograph cloner object and have noticed that only a 1 of each object has the outlines. I suspect it is to do with hierarchies but can’t find the switch to resolve this.
    If i remove the add’l objects so only 1 remains in the cloner, only 1 clone has outlines.
    I’ve posted a still of my setup and outlined the areas of concern and where i believe the answer is to be found…but no luck.
    https://screencast.com/t/92IqjhCW
    pwd: jingles
    Any ideas?
    thanks!
    Jay Ingles replied 14 years, 2 months ago 1 Member · 1 Reply
  • Jay Ingles
    July 5, 2012 at 1:51 pm
    Solved.
    Render Instances was checked. Unchecking resolves this.
