Activity Forums Maxon Cinema 4D Sketch & Toon/ getting lines to calm down
  • Sketch & Toon/ getting lines to calm down
    Posted by Scott Frizzle on July 14, 2005 at 7:49 pm
    I’m using S&T in an animation and I’m using the frame match feature to keep my lines form jumping around. When I try to render my animation, it renders the first frame and then hangs indefinitely while trying to create the second. There are no animated stroke parameters, and the scene has a consistent poly count throughout, so it’s not as if there is some event in the second frame that would cause this problem. Any ideas?
    Also, any tips on keeping S&T lines from jumping around during an animation would be appreciated.
    Scott Frizzle replied 21 years, 1 month ago 1 Member · 0 Replies
  • 0 Replies
