Activity Forums Maxon Cinema 4D Sketch and Toon?
  • Sketch and Toon?
    Posted by Amish Ed on September 18, 2006 at 10:29 pm
    I’ve got an object in which I’ve used Sketch and Toon to create a wireframe. But, it doesn’t show up in any reflections or cast any shadows. Am I’m missing something here, or is that just the wasy S&T works? Thanks….
    Amish Ed
    “Shoot ’em all and let the Editor sort ’em out!”
    Dual 2Ghz G5, 4GB, running 10.3.6 w/QT 6.5.2, Black Majic DeckLink, AE Pro 6.5 w/BCC and Invig. 3D, PS CS2, AI CS2, FCP HD
    Richard Powell replied 19 years, 11 months ago 3 Members · 4 Replies
  • Mylenium
    September 19, 2006 at 5:43 am
    Yepp, since the strokes are created as a post processing effect, they don’t show up in raytracing. This is a limitation you have to accept. If you really only need a wireframe, look into other options like using Atom Array or third-party plugins that work based on creating “real” geometry.
    Mylenium
    [Pour Myl
  • Amish Ed
    September 19, 2006 at 3:50 pm
    Thanks Mylenium, pretty much what I figured. Any recomendations? Atom Array won’t work because I want a very regular, even mesh.
    Amish Ed
  • Mylenium
    September 19, 2006 at 4:34 pm
    I’m using Tessa from the DiTools quite a bit. I believe there was a wire shader from Vreel once upon a time if I recall correctly, but it seems to not be cared for anymore so it’s not compatible with newer versions of C4D.
    Mylenium
    [Pour Myl
  • Richard Powell
    September 19, 2006 at 7:25 pm
    Paul Everett’s ‘Wireshader’ is now free at C4D Portal.
    https://www.c4dportal.com/forum/showthread.php?p=3650
