Activity Forums Maxon Cinema 4D Sketch and Toon – transparent stroke
  • Sketch and Toon – transparent stroke
    Posted by George Tsirogiannis on September 27, 2014 at 1:58 pm
    Hello! I’ll be using Sketch and Toon on Cinema 4D R15 to create a pseudo-3D animation.
    I’ll have a simple character in a totally-flat environment (no shadows, no reflections etc, just a single color on the background and a single color on each object).
    I set Sketch and Toon to draw lines only when parts of the same object/character overlap (ie when a hand overlaps with the same character’s chest). What I’d like to do is to set the Sketch and Toon stroke “erase” the parts of the character that it’s drawn on and see what’s behind through the stroke. How could I achieve that?
    George Tsirogiannis replied 11 years, 12 months ago 2 Members · 6 Replies
  • Brian Jones
    September 27, 2014 at 7:49 pm
    not directly, I think. You would probably have to try it in post with a multipass render, S&T has settings in it for multipass rendering and you can ask for a separate alpha channel (for the lines)
  • George Tsirogiannis
    September 27, 2014 at 8:31 pm
    Thanks for responding! How can I do that? Could you point it out for me?
  • Brian Jones
    September 27, 2014 at 8:42 pm
    Render Settings/Sketch and Toon/Multi-Pass/Separate Alpha
    September 27, 2014 at 8:45 pm
    No “Multipass” tab on my end! I’ve got R15, maybe they’ve changed it. Will have to look it up.
  • Brian Jones
    September 27, 2014 at 8:52 pm
    in 15 you’d have to check Post Render in the S&T Render tab to get the Multipass tab to show but it is there. The line quality is a bit different with that checked but hopefully it’s good for what you want.
    September 27, 2014 at 11:21 pm
    Okay, thanks a lot!
