Activity › Forums › Maxon Cinema 4D › sketch and toon outline on bevel/round corner
  • sketch and toon outline on bevel/round corner
    Posted by Benedict Hein on November 13, 2017 at 10:08 am
    Hi there,
    I got some metal connectors which I need to visualize “in action”. So the main piece textured, the other parts where it is connected to just outline.
    But I can’t get the lines on the round/beveled corners to show up…. Anyone got an Idea how to do it?
    Here is how far I got:
    These are the lines I need:
    Fully textured, so you get a better Idea of the geometry:
    Benedict Hein replied 8 years, 10 months ago 2 Members · 2 Replies
  • Adam Trachtenberg
    November 14, 2017 at 5:35 pm
    You can get lines on those bevels by using the Angle line type in the Render Tag’s Lines tab. You’ll need to adjust the Min/Max angles if you want a single line.
    I’ve set up an object with one beveled edge and applied two sketch materials to it: one for just the bevel and one for the other edges. If you want the same line you can use a single material.
    File: 11861_sketchbevelline.c4d.zip
  • Benedict Hein
    November 15, 2017 at 8:13 am
    Well… this works just fine. Thank you so much!
    With all the settings already available in the material and the sketch render settings I didn’t even think about the possibility of using a tag 😀
