Activity › Forums › Maxon Cinema 4D › Sketch and toon lines
Posted by Gopal Reghunath on February 8, 2011 at 10:52 amIs it possible with the sketch and toon module to get only the wireframe of a model in rough sketch lines? And can I get it with alpha?
Gopal Reghunath replied 15 years, 7 months ago 2 Members · 8 Replies -
Brian Jones
February 9, 2011 at 12:48 amRough sketch lines yes, what do you mean by alpha? Alpha in the scene or are you going to add it to something in post?
Gopal Reghunath
February 9, 2011 at 4:34 amYeah im taking it to post. As I want to combine it with other motion graphics. So I want only the rough sketch lines preferably along with an alpha channel of it.
Brian Jones
February 9, 2011 at 7:44 pmit’s possible, just put a material on your object that is pure alpha, set your S&T settings as you like but set Shading/Background and Object to Off. Oh yeah, enable Alpha Channel in the Render Settings too…
Gopal Reghunath
February 10, 2011 at 6:55 amIm sorry,I dont understand. Can you explain it in detail? This is the exact way i want it to look. But i want to keep an object behind these sketches in AE.
Some contents or functionalities here are not available due to your cookie preferences!This happens because the functionality/content marked as “Vimeo framework” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
Brian Jones
February 10, 2011 at 4:09 pmThis makes an alpha that works. It works with QT Animation codec set to Millions of Colors + or if you prefer an image sequence, TIFF, PSD etc…
Gopal Reghunath
February 11, 2011 at 4:58 amThank you so much Brian.
Is this done in C4D R12? Beacause it says that it is unknown file format for me. I have 11.5 Damn. -
Brian Jones
February 11, 2011 at 5:16 pmYeah, that’s R12, here’s more or less the same thing in 10.5 format (I never had 11). This is done the same as the R12 file. An alpha material on the object (a sphere) and in the S&T Effect Render Settings/Mode set to Include and the sphere added there but it can also be done with a Sketch Style tag on the sphere instead.
