Activity Forums Maxon Cinema 4D Sketch and toon lines badly drawn/broken?
  • Sketch and toon lines badly drawn/broken?
    Posted by Chris Holland on August 2, 2019 at 2:14 pm
    Incredibly new to Cinema 4D… I just needed a stroke 3D rigged robotic arm and I thought i’d give cinema 4D a go to achieve it. I managed to do it perfect the first time round but the client wants to change the model. I thought, sure – should be easy enough, same process as the last one. wrong. It looks completely different!
    I’ve played with the creases and pretty much everything else on that render settings panel and I can’t seem to sort the lines out. They are very much broken/badly drawn. I have attached my first attempt which worked perfect and how I’d like it to end up and a screenshot of what I’m currently working with.
    Any help would be awesome!!!
    Thank you in advance
    First attempt, how I want it to look:
    13600_screenshot20190802at15.04.17.png.zip
    What I’m currently working on… Why are the lines so rough!?
    13602_badlines.jpg.zip
    Brian Jones replied 7 years, 1 month ago 2 Members · 1 Reply
  • Brian Jones
    August 3, 2019 at 8:18 pm
    probably have to see the scene file to find out what’s going on
