Activity › Forums › Maxon Cinema 4D › Sketch and Toon Colour and texture transition
  • Sketch and Toon Colour and texture transition
    Posted by Martyn Morris on October 18, 2009 at 3:51 pm
    Hi there,
    I have set up some houses and applied sketch and toon to them.
    On one of the houses I key framed to go from gray to white and applied an PSD texture of cracks.
    The cracks are supposed to fade out over a second but do not show up though out the animation.
    Any help would be much appreciated.
    Thanks, Martyn.
    Martyn Morris replied 16 years, 11 months ago 2 Members · 2 Replies
  • Brian Jones
    October 18, 2009 at 7:37 pm
    It depends on the setup, there’s more than one way to do it but probably you want to go the Shading tab of the Sketch Style Tag and check ‘Enable’ there but set ‘Object’ to Off. That allows you to use other textures to define the shading but keep the lines from the Sketch material. A quick example using two textures, one for color and one for cracks alpha’d on top – but it can be done with one texture and different set ups as well. It’s set up assuming I understand your description, grey with cracks and the cracks disappear as it goes to white and with noise instead of a psd for cracks…
    334_sketchtest.zip
  • Martyn Morris
    October 20, 2009 at 2:55 pm
    Hi Brian,
    Thanks for your reply it was very helpful.
    I had forgot about noise.
    Thanks again.
    Martyn.
