sizing the blurring
Posted by Doyal Gudgel on August 22, 2011 at 4:15 pmas you can see by the picture there is blurring but where is the page to size the blurring?
Hope to see you
https://seniorobserver.blogspot.com, https://billswar2.blogspot.comJohn Rofrano replied 15 years ago 3 Members · 5 Replies -
Doyal Gudgel
August 22, 2011 at 5:18 pmWhat I want is this (from help) Video Event FX dialog/ Where is the video fx dialog?
Hope to see you
https://seniorobserver.blogspot.com, https://billswar2.blogspot.com -
Mike Kujbida
August 22, 2011 at 5:59 pmVideo FX means whatever video effect you’ve applied to the event.
In your case, you size it using the Cookie Cutter FX as I demonstrated in this post.
https://forums.creativecow.net/readpost/208/879044 -
Doyal Gudgel
August 22, 2011 at 6:29 pmOK I understand that but how do I get there from the window I posted in the first post.
Hope to see you
John Rofrano
August 22, 2011 at 7:44 pm[doyal gudgel] “as you can see by the picture there is blurring but where is the page to size the blurring? “
You need to add the Cookie Cutter after the Blur. The Cookie Cutter will control the Blur (but only if you add it to the FX chain)
Like this:
~jr
http://www.johnrofrano.com
http://www.vasst.com -
John Rofrano
August 22, 2011 at 7:51 pm[doyal gudgel] “OK I understand that but how do I get there from the window I posted in the first post.”
Press the Plug-in Chain… button (then add Cookie Cutter):
~jr
