Activity Forums DaVinci Resolve Sizing from FCP XML not correct in Resolve
  • Sizing from FCP XML not correct in Resolve
    Posted by Jeff Cotten on August 19, 2013 at 7:56 pm
    I have a 1080 timeline with 4K files. I did some resize in FCP7 and exported an XML to resolve. On import of the XML I checked the “Use sizing information”. The resizing in Resolve is smaller and not at all correct. Does FCP7 sizing information work correctly in Resolve? Thanks.
    Jeff Cotten replied 13 years ago 2 Members · 2 Replies
  • Chris Martin
    August 21, 2013 at 5:33 am
    XML repo info works fine. Your problem is probobly due to how you have your config settings for scaling into an HD timeline. Sounds like you may be set to scale image to fit and you may need to be on another option. It needs to match how you were set to work in FCP. You may be doubling up on your scaling so to speak.
  • Jeff Cotten
    August 21, 2013 at 1:22 pm
    That was it. I needed to have “Mismatched resolution” set to “center crop with no resize”
    Thanks for your help.
