Activity Forums Adobe Media Encoder Size of exported videos has changed out of nowhere.
  • Size of exported videos has changed out of nowhere.
    Posted by Max Smith on April 5, 2016 at 11:08 pm
    Hello,
    Starting about a week ago my file size for my exported videos has increased.
    Before when I was exporting a 15 second video the file size was around 5-10 MB.
    Now all of the sudden my file size for the exact same video is about 60MB.
    I’m wondering what may have caused this and how to fix it. I have not made and major changes in the past 2.
    My export settings are
    Format: H.264
    Dimensions: 960 x 540
    Frame Rate: 23.976
    Field Rate: Progressive
    Aspect: Square Pixels (1.0)
    TV Standard: NTSC
    Profile: High
    Level: 4.0
    Bitrate Encoding: VBR, 2 Pass
    Target Bitrate (Mbps): 2.5
    Maximum Bitrate: 4.5
    Keyframe Distance 72
    Please let me know if there is something that may be causing this or if you think you may know a solution on how to fix this.
    Thank you so much for your time and help.
    Max
    Max Smith replied 10 years, 5 months ago 2 Members · 2 Replies
  • Jon Doughtie
    April 6, 2016 at 9:10 pm
    h.264 is the codec as opposed to the format (or wrapper). What is the file extension of your finished renders? Did that change?
    Are you working from a custom preset you use regularly?
    System:
    Dell Precision T7600 (x2)
    Win 7 64-bit
    32GB RAM
    Adobe CC 2014 (as of 7/2015)
    256GB SSD system drive
    4 internal media drives RAID 5
    Typically cutting short form from HD MP4 and P2 MXF.
  • Max Smith
    April 7, 2016 at 2:40 pm
    The file extension is .mp4
    I am working from a custom preset, however I tried the export without using my usual preset with the same settings and I got the same result.
