Activity › Forums › Apple Final Cut Pro Legacy › size chart for still pics in PS that are to be used in video
Posted by Zman on September 14, 2006 at 4:58 amsize chart for stills in PS that are to be used in video, I use to have a chart telling what size to create photoshop pics so that they work / look correct in video, SD / PAl / HD, stuff like that. anyone know where to find this?
Kevin Monahan replied 19 years, 12 months ago 4 Members · 3 Replies -
Chris Wyatt
September 14, 2006 at 7:01 amYou don’t need a chart if you use Photoshop 7.0 or above.
When making a new file there are presets for all the sizes you mentioned
as well as their aspect ratio conversions in NTSC and PAL.Best Regards
Bob Flood
September 14, 2006 at 3:04 pmandrew
1. take a frame from the video you want to put type over an export it as a pict. bring it into photoshop, select all, copy and open a new document. the new doc will be the size you need for video. it may not look right because of pixel aspect ratio, but it will be the correct dimensions
2, google it.. try “video formats explained”, “video aspect ratios explained”, “high def” etc
there are tons of resources for just this, even here at the cow
Kevin Monahan
September 15, 2006 at 1:35 am[footagehead] “You don’t need a chart if you use Photoshop 7.0 or above.
as well as their aspect ratio conversions in NTSC and PAL.”GOTCHA!
What you say is untrue.
Apple has a totally different pixel aspect ratio than Adobe Premiere, AE, etc.
Therefore, the presets are not correct if you plan to finish on FCP.https://docs.info.apple.com/article.html?artnum=36836
Andrew, you’ll find your chart there.
[Apple] Other software programs may use different aspect ratios and recommend different imported graphics sizes. However, if the material is going to be edited in Final Cut Pro, the above recommendations should be followed.
Kevin Monahan
Take My FCP Master’s Workshop!
fcpworld.com
Pres. SF Cutters
