Activity Forums Maxon Cinema 4D sissor joint
  • sissor joint
    Posted by Ronny Traufeller on March 9, 2011 at 2:07 pm
    hey!
    two questions:
    first:
    was thinking about creating a scissor joint situation, but in the end it hurts my brain a bit to much 🙂
    something like that:
    https://www.newgape.de/media/images/info/image_11100402_1.jpg
    maybe a couple of 2 piece joints along a ik spline could do the job,
    but thats to messi and unattractive to build.
    did anyone knows a good way, espiacially something that is able to bend maybe …
    second:
    when i scale an ik-spline, it seems that it is not scaling the tangents i think, so the rig starts to fold itself and make strange stuff.
    did anyone had the same problem before?
    thanks,
    Ronny!
    traufeller.de
    Ronny Traufeller replied 15 years, 6 months ago 2 Members · 2 Replies
  • Adam Trachtenberg
    March 9, 2011 at 5:56 pm
    Regarding the scissor joint, there’s probably a really clever way to do it using constraints and some math, but that’s not how my brain works. But I was able to put something together using MoGraph and a little Xpresso. The spline wrap can be applied to provide a bend.
    1735_accordionjoint.c4d.zip
    As for the second question, I don’t think you should be scaling the IK spline; rather, move the handles to change the length.
  • Ronny Traufeller
    March 10, 2011 at 2:52 pm
    thanks for your file, seems that pretty much people using r12 here, i am on 11.5 🙁 (there should be a way export to older versions !?)
    the thing with the scaling is just occuring when i import charakter
    into a scene where it needs to be scaled to fit in the scene. thats nothing i can abandon, i cant scale the scene to fit to the rig. but i just relized that problem after building that complex rig. noooooo!
    thanks,
    Ronny!
    traufeller.de
