Activity › Forums › Maxon Cinema 4D › Single texture across multiple polygons
  • Single texture across multiple polygons
    Posted by Matt Deloach on October 1, 2013 at 3:14 am
    I’m fairly new to the Cinema 4D world and I have a question that I’m sure should be simple to answer for someone out there.
    I have 16 polygons (squares in a grid) that I’d like to apply a single texture or video to. I will attach a screenshot to this post.
    Is there a fairly simple way to apply a single texture or video to all of the polygons? In Illustrator or After Effects, you would simply apply a complex mask (or shape layer) to said image or video. I’m at a bit of a loss as to how to accomplish this in Cinema 4D.
    Could someone out there please lend some advice? I appreciate it!
    Matt
    Matt Deloach replied 12 years, 12 months ago 3 Members · 4 Replies
  • Brian Jones
    October 1, 2013 at 1:36 pm
    put all the squares in a Null and apply the texture to that – set it to Flat and move it around with the texture tools to get the alignment and size you need. If the squares are done with a Cloner (not just 16 separate objects) then you don’t need the null you can do the same thing with the Cloner
  • Matt Deloach
    October 1, 2013 at 3:13 pm
    Thanks for the advice…the null method works, but for some reason, not when I set the texture projection to flat. Nothing is rendered when it is set to flat.
    When I set the projection to “frontal” it displays in the squares, but they don’t rotate, pan or zoom with the camera. The video plays in a fixed position.
    Any idea on how to fix this? Thanks again…
  • Adam Trachtenberg
    October 1, 2013 at 5:12 pm
    Hard to say but you may have the flat mapping rotated 90 degrees to the surface. Here’s a quick demonstration applying flat mapping to a 4×4 grid of polygons: https://www.youtube.com/watch?v=t_rcef-Npt4
  • Matt Deloach
    October 3, 2013 at 6:19 pm
    Awesome. Thank you!
