Activity › Forums › Apple Final Cut Pro › Single roller trim with dissolve
  • Single roller trim with dissolve
    Posted by Oliver Peters on November 26, 2011 at 6:08 pm
    I may be missing this somewhere. Can you do a single roller trim when a dissolve is there, using just the trim tool (not precision editor)? Everything I try simply changes the dissolve duration, but doesn’t lengthen or shorten the end of the A or B side of a shot change. Seems you have to use the precision editor – or alternatively – remove the dissolve, trim and add the dissolve back.
    – Oliver
    Oliver Peters replied 14 years, 10 months ago 2 Members · 2 Replies
  • Tom Wolsky
    November 26, 2011 at 6:29 pm
    There is a bar at the top of the transition. The handle in the center of the bar will roll; the handles on the end will ripple.
    All the best,
    Tom
    Class on Demand DVDs “Complete Training for FCP7,” “Basic Training for FCS” and “Final Cut Express Made Easy”
    Coming in 2011 “Complete Training for FCPX” from Class on Demand
    “Final Cut Pro X for iMovie and Final Cut Express Users” from Focal Press
  • Oliver Peters
    November 26, 2011 at 7:40 pm
    Got it. My mistake was inadvertently selecting the dissolve first. Thanks.
    – Oliver
    Orlando, FL
    http://www.oliverpeters.com
