Activity Forums Blackmagic Design Single Field Out when Paused – bug
  • Single Field Out when Paused – bug
    Posted by Felix Mack on January 30, 2006 at 12:51 am
    On an NTSC setup, when you insert edit a clip into a sequence already on digibeta, the first frame (in point) has a weird half-rez look to it. It’s easy to see the single field frame on something like a title logo, or other static images. It looks like a sudden 1 frame drop in resolution.
    I found this problem occurs when in System Prefs, the ‘Single Field Out when Paused’ is checked.
    When you uncheck this option the field goes in clean on the first frame. Can this be fixed?
    Also, what about the infamous gamma issue, what’s happening with that? It’s been months since was first brought up . . .
    Felix Mack replied 20 years, 6 months ago 3 Members · 4 Replies
