Activity › Forums › Adobe After Effects › Single-button vignette layer?
  • Single-button vignette layer?
    Posted by Eric Chard on September 27, 2018 at 5:35 pm
    Is there any tool/script that would generate a vignette layer at the touch of a button?
    Ideally, such a tool would:
    generate a full-comp black layer;
    add an inverse mask to it;
    feather the mask by some fraction of the X&Y;
    possibly add some bezier corners and midpoints;
    set the blending mode to DARKEN/MULTIPLY.
    I think that’s my whole wish list. I know I’ve written a lot of the pseudo-code above. The tricky bits would be making it universal for any shape comp.
    But, thought I’d check FIRST.
    “Putting the HARM in ‘harmonica’ since 2005.”
    Cassius Marques replied 8 years ago 3 Members · 2 Replies
  • Kalleheikki Kannisto
    September 27, 2018 at 6:55 pm
    How about: Effects&Presets panel>Animation presets>Vignette Lighting
    Senior Graphic Designer
  • Cassius Marques
    September 27, 2018 at 7:09 pm
    Well, if you can do it with effects, the circle effect alone can get you 90% of the way, you could save it as a preset and just double click it anytime you want, without nothing selected it would create a comp size grey solid and apply. (You already have the Vignette Lightning preset to test it)
    But really, how many times a day do you need that? Cause personaly I just do: Crtl + Y, set to black, double click round mask tool, Ctrl + Shift + I, “f” to feather. Its like 10s. Even though I have access to the Sapphire Vignette plugin thats pretty robust, I rarely use it.
    Cassius Marques
    http://www.zapfilmes.com
