Activity › Forums › Adobe After Effects Expressions › Simulating web cursor (arrow/hand) rollover
  • Simulating web cursor (arrow/hand) rollover
    Posted by Tim Drage on October 8, 2010 at 1:02 pm
    I am working on an animation of a website, simulating the cursor, rollovers etc all in AE. I have button rollovers working OK (based this script – https://forums.creativecow.net/archivepost/2/405515) but I would also like the cursor graphic to switch from arrow to hand pointer when it rolls over any of the multiple buttons in the comp.
    The bit I can’t figure out how to do is how I’d expand the script to detect whether it’s over any one of several layers?
    Any ideas would be greatly appreciated, thanks!
    Tim
    Tim Drage replied 15 years, 11 months ago 2 Members · 2 Replies
  • Dan Ebberts
    October 8, 2010 at 7:21 pm
    Here’s one that checks to see if the upper left corner of the layer with the expression is over any of the layers in the array “layerNames”. If it is, it gives the index of that layer. If not, the result it zero. Might get you headed in the right direction.
    layerNames = ["Layer 1","Layer 2","Layer 3"]
    pointer = [0,0]; // upper left corner
    target = null;
    for (i = 0; i < layerNames.length; i++){
    L = thisComp.layer(layerNames[i]);
    p = L.fromWorld(toWorld(pointer));
    if (p[0] >= 0 && p[0] <= L.width && p[1] >= 0 && p[1] <= L.height){
    target = L;
    break;
    if (target == null) 0 else L.index
    Dan
  • Tim Drage
    October 12, 2010 at 2:37 pm
    Thanks very much for the quick reply, just had the chance to give it a test and it’s going to work a treat I think. 🙂
