Activity › Forums › Apple Motion › Simulating planets around sun – having 2.5D trouble.
  • Simulating planets around sun – having 2.5D trouble.
    Posted by Tangier Clarke on February 7, 2013 at 10:27 pm
    The planets are basically circles. The Sun is also a circle with the sphere filter on it because I used a rectangular image of the sun; animating the revolutions using the sphere filter position properties.
    I have the planets (circles) on a circular motion path, rotated 90 degrees so the circular path is on a horizontal plane.
    I just can’t figure out how to get the planets to “disappear behind the sun. My circular motion path is larger than the sun sphere.
    I’ved toyed around with the z parameter of the different object groups with no luck yet.
    Any advice?
    Tangier
    Mark Suszko replied 13 years, 7 months ago 2 Members · 2 Replies
  • Tangier Clarke
    February 7, 2013 at 10:54 pm
    Lol – figured it out. Never the less if anyone has insight into this, it’d still help.
    I suppose I should have just used Blender to “really” do it right.
    T
    Tangier
  • Mark Suszko
    February 15, 2013 at 10:01 pm
    What was your solution, BTW?
