Activity Forums Adobe After Effects Expressions Simulating a growing shadow
  • Simulating a growing shadow
    Posted by Kim Petersen on February 20, 2009 at 9:35 pm
    Hi there,
    perhaps you expression gurus can help with this one. I need to simulate a shadow growing and I would like to see if this can be done with expressions only.
    I have a flat product image moving on the y axis. Now, as the object comes closer to the floor (the floor doesn’t exist. The shadow only hints that it exists). I want the shadow to grow as well.
    Any ideas?
    Kim
    Kim Petersen replied 17 years, 7 months ago 2 Members · 2 Replies
  • Brendan Mccullough
    February 20, 2009 at 9:57 pm
    Make a new solid in whatever color you want your shadow to be, double click the elliptical mask tool to create a new circular mask on it, feather it out (make to look shadowy, if that’s a word 😉 ), make this layer 3D, and orient it underneath your product layer to your liking.
    Then, link the Y position of the product to the scale (and maybe even the opacity) of the shadow layer using the linear() (or ease()) function something like this:
    productPos = pickwhip to your product layer's y-position;
    bottom = y value of product at rest on the 'floor';
    top = y value of product as high as you want to make it;
    shadowSmall = whatever size the makes the shadow look correct when the product is at rest;
    shadowLarge = whatever size makes it look correct when the product is in the air. Eyeball it;
    linear(productPos, bottom, top, shadowSmall, shadowLarge);
    Apply the same concept to opacity. Dig it?
  • Kim Petersen
    February 21, 2009 at 8:59 am
    I dig!
    Thanks Brendan 🙂
    /Kim
