Activity Forums Adobe After Effects Expressions Simulate CC Sphere as 3D object
  • Simulate CC Sphere as 3D object
    Posted by Tim Fast on August 9, 2010 at 12:03 pm
    I have an object made by CC Sphere effect. The problem is that when the camera flies around the 2D nature of the effect is revealed. Yes, the object is always oriented towards the camera but the applied texture and the lighting won’t rotate in the same degree as the camera changes its position.
    Thus, I wonder if there is an expression (or few ;-)) that can handle the problem? Is it possible at all?
    Tim Fast replied 16 years ago 2 Members · 3 Replies
  • Kevin Camp
    August 9, 2010 at 6:26 pm
    check out this page:
    https://aeportal.blogspot.com/2010/02/fly-around-cc-sphered-layer-in-after.html
    i found this link in ae’s livedocs under the layer space transform expressions section…
    Kevin Camp
    Senior Designer
    KCPQ, KMYQ & KRCW
  • Tim Fast
    August 9, 2010 at 6:44 pm
    Thank you Kevin! It looks like there are plenty of links from that page. I will investigate them. 🙂
  • Tim Fast
    August 15, 2010 at 2:50 pm
    I didn’t need the links! All the code is at the main page. Everything works as advertised. That’s exactly how I wanted it to work! 🙂 Thanks again Kevin! And thank you Filip too. That’s the second time I use your code in my project. 🙂 Something tells me that this is not the last time either. 😉
