Activity Forums Adobe Premiere Pro simply redig a sequence
  • simply redig a sequence
    Posted by Tony Brecknock on October 25, 2011 at 5:25 pm
    I have imported some footage from XDCAM HD, base cut a piece and now want to redig it through HDSDI. I gave the imported clips a reel number and can redig the whole bin that made the sequence no problem but for the life of me I can’t figure out how to just redig the sequence I cut to save space and time. I exported an edl but it split all the video and audio into seperate clips. I am looking for a simple way to redig a sequence.
    Alex Udell replied 14 years, 11 months ago 2 Members · 3 Replies
  • Alex Udell
    October 25, 2011 at 7:40 pm
    Here’s a guess….
    Project Manager > Create a trimmed project with media offline
    this would create a project with a sequence with trimmed edits and corresponding source that you could then recap…
    I believe this is correct….
    Can anyone back me up on this?
    see below from CS3, but this should still hold true.
    https://livedocs.adobe.com/en_US/PremierePro/3.0/help.html?content=WS1c9bc5c2e465a58a91cf0b1038518aef7-7c74.html
    remember non tape based sources can’t be consolidated.
    lemme know…
    Alex
  • Tony Brecknock
    October 25, 2011 at 8:20 pm
    thanks I will try it, so suffice it to say that re digitizing a sequence is a project based thing in Premiere, there isn’t a re do sequence?
    Tony
  • Alex Udell
    October 25, 2011 at 8:30 pm
    I believe that is the case.
    note the following:
    1) in the Project manager window you should be able to specify the sequence(s) for “managing”
    2) after you’ve created the project from that sequence, you could always import that Project into your master, it would just then show up as a bin with all the offline assets inside it.
    So you end up where I think you want to be…
    Alex
