Activity › Forums › Apple Final Cut Pro › simple way to make an audio only crossfade?
  • simple way to make an audio only crossfade?
    Posted by Jack Niedenthal on May 27, 2012 at 7:05 am
    I have read a few threads about this and there is apparently no way to a simple very short audio only transition to say get rid of a slight pop without detaching audio, etc. Has anyone created a transition that can be added to FCPX that could accomplish this by simply dragging it between two audio clips? The old FInal Cut had audio transitions which you could just drag into place like a +3 dB cross fade (the default) and a 0 dB cross fade.
    Jack Niedenthal
    Microwave Films of the Marshall Islands
    http://www.microwavefilms.org
    iMac i7 using Lion 10.7.x, HPX 170 using only one 64GB card
    I live on an island in the middle of the Pacific, YOU are my only resource.
    James Shih replied 11 years, 6 months ago 8 Members · 7 Replies
  • 7 Replies
  • Tom Wolsky
    May 27, 2012 at 7:41 am
    You don’t need to detach the audio. You can simply double click it to expand it to create a quick audio fade using the fade handles. Alex Gollner at alex4d has a free audio cross fade.
    All the best,
    Tom
    “Final Cut Pro X for iMovie and Final Cut Express Users” from Focal Press
    Class on Demand DVDs “Complete Training for FCP7,” “Basic Training for FCS” and “Final Cut Express Made Easy”
    Coming in 2012 “Complete Training for FCPX” from Class on Demand
  • Tony Sarafoski
    May 27, 2012 at 10:57 am
  • Bill Davis
    May 27, 2012 at 11:51 pm
    I know you want something “drag and drop” and others have explained that.
    However it’s also useful to understand that in X, every audio clip has a built in fade handle at the beginning and end of every audio clip by default.
    Just point your selection tool to the place where the audio level line hits the beginning or end of any clip, click and drag “into” the clip and you’ll get an instant fade slope.
    One of thousands of super fast shortcuts built into X.
    FWIW.
    “Before speaking out ask yourself whether your words are true, whether they are respectful and whether they are needed in our civil discussions.”-Justice O’Connor
  • Oliver Peters
    May 28, 2012 at 2:52 pm
    [Bill Davis] “However it’s also useful to understand that in X, every audio clip has a built in fade handle at the beginning and end of every audio clip by default. Just point your selection tool to the place where the audio level line hits the beginning or end of any clip, click and drag “into” the clip and you’ll get an instant fade slope.”
    It’s worth pointing out that this concept of fade handles was borrowed from Soundtrack Pro. Except in STP, when you perform the same function, an audio crossfade (dissolve) is automatically created when the two clips butt up against each other.
    – Oliver
    Orlando, FL
    http://www.oliverpeters.com
  • Steve Connor
    May 28, 2012 at 4:36 pm
    [Oliver Peters] “an audio crossfade (dissolve) is automatically created when the two clips butt up against each other.”
    I forgot about that, time to submit a feature request!
    Steve Connor
    “Sometimes it’s fun to poke an angry bear with a stickl”
    Adrenalin Television
  • Jeff Morgan
    February 25, 2013 at 6:57 pm
    No audio handle in a multicam clip. You don’t have a simple solution for this do you?
  • James Shih
    March 23, 2015 at 9:37 pm
    If you right click on the video clip and select detach audio, you can then just apply the cross dissolve transition to the audio clip. That should work.
