Activity Forums Adobe After Effects Expressions simple syntax question
  • simple syntax question
    Posted by Jonas Espinoza on March 27, 2008 at 7:16 pm
    so i am becoming semi-friendly with arrays, and slowly better at syntax
    right now i am just perplexed on something simple
    i am not sure how the syntax works when adding say a wiggle on top of the x variable. do i put it below in the array, or is there a way to tack it on to the x = line. Ive played around for a while now, and im just not getting it.
    x= comp(“master”).layer(“Controller”).effect(“width”)(“Slider”)*2*(index-1);
    y= position [1];
    [x, y]
    Dan Ebberts replied 18 years, 3 months ago 2 Members · 4 Replies
  • Dan Ebberts
    March 27, 2008 at 11:50 pm
    You’ll need to do something like this:
    freq = 2;
    amp = 25;
    y= position [1];
    w = wiggle(freq, amp) – value;
    [x, y] + [w[0],0]
    Dan
  • Jonas Espinoza
    March 28, 2008 at 2:26 am
    ah
    makes perfect sense, learning the way to speak this script is the key
    thanks so much
    you are such a HUGELY generous contributer to this community
  • Jonas Espinoza
    March 28, 2008 at 4:36 pm
    [x, y] + [w[0],0] ”
    i’m not clear about the “- value” part
  • Dan Ebberts
    March 28, 2008 at 4:56 pm
    The result from wiggle() includes the value of the property itself. To isolate just the wiggle part you need to subtact out the pre-expression value. Hope that makes sense. 🙂
    Dan
