Activity Forums Boris FX Particle Illusion Simple rotation of a single particle?
  • Simple rotation of a single particle?
    Posted by Robert Coleman on May 21, 2008 at 8:23 pm
    I’ve had PI for about a month and have been working my tail off to get good at it. One effect that I have had only modest success with is taking a single particle (such as a circular picture) and rotating it around the center axis smoothly. The best I have done so far is to use a small number of particles which flicker somewhat, speed up and slow down.
    Of course, PI is not intended as a basic animation product, but it seemed to me that it should be easily capable of simple moves such as this. Am I wrong?
    Robert
    Alan Lorence replied 18 years, 4 months ago 2 Members · 1 Reply
  • Alan Lorence
    May 22, 2008 at 12:58 pm
    Take a look at the “mouse” emitter in the default library. It uses the “single” option in the emitter properties dialog.
    Once your emitter contains a “single” particle, you can animate the “angle” property to rotate it.
    Alan.
    http://www.wondertouch.com
