Activity › Forums › Adobe After Effects › Simple Ramp
  • Simple Ramp
    Posted by Mike Sussman on May 14, 2009 at 1:48 pm
    This feels like a stupid question but why can’t the Start of Ramp (coordinates) and End of Ramp (coordinates) be adjusted when making a simple ramp? They’re red and changing them immediately pops back to the locked in values of 360,240/0,0. Why even have value settings that can’t be used? If the answer is “they just can’t be changed” then what’s your recommended easy workaround?
    Mike Sussman replied 17 years, 4 months ago 3 Members · 3 Replies
  • Todd Kopriva
    May 14, 2009 at 2:37 pm
    Did you apply the Ramp effect directly, or was it applied as part of an animation preset? The red text makes me think that you applied this as part of an animation preset, and these properties have some expressions on them that are defining their values.
    putting the ‘T’ back in ‘RTFM’ : After Effects Help on the Web
  • Kevin Camp
    May 14, 2009 at 3:29 pm
    yep, apply the ramp effect from effects>generate>ramp and see if you have better luck…
    Kevin Camp
    Senior Designer
    KCPQ, KMYQ & KRCW
  • Mike Sussman
    May 14, 2009 at 6:40 pm
    I didn’t see any preset set, and it specifically said None for the preset, but when I clicked on Reset the values did turn blue again. I guess, even though it said none for preset it was really there somehow. Odd. Thanks.
