Activity Forums VEGAS Pro Simple question – whats the answer please – HDV to normal screen
  • Simple question – whats the answer please – HDV to normal screen
    Posted by Jeremy Rochefort on May 12, 2005 at 9:31 pm
    Hi all
    I am struggling with trying to get HDV footage (FX1 set to 4:3) to render to normal screen height and width (no letterbox as with widescreen) – iow, the video must fill the screen (PAL) – as requested by client.
    I have my project set up as 720 x 576, 1.0926 (PAL DV), PAL DV (720×576, 25.000 fps).
    How do I render this project to get what I am after or which aspect setting do I need to change to achieve this.
    Please forgive my ignorance as I am new to this so any help would be greatly appreciated
    Sorry about the double post, I accidentally clicked the “Post Direct” button before I was finished.
    Many thanks
    Jeremy
    Never let the need for money outweigh the need for Quality, Friendly & Proffessional Service
    Jeremy Rochefort replied 21 years, 3 months ago 3 Members · 5 Replies
  • Dan Achatz
    May 13, 2005 at 12:33 am
    Go into the event pan and crop set the following settings
    Position
    Width 978
    Height 1080
    x center 720
    y center 540
    Angle
    angle o
    x center 720
    y center 484
    Key frame
    Smooth 0
    Source
    maintain aspect ration no
    Stretch to fil frame yes.
  • Jeremy Rochefort
    May 13, 2005 at 6:08 am
    Many thans Dan
    These settings worked – however, why does the output now appear “squashed” horizontally
    Regards
    Jeremy
  • Dan Achatz
    May 13, 2005 at 6:49 am
    I’m not sure? It rendered Ok for me. Are you sure you set the maintain aspect ratio to: no.
    Also what are you rendering to.If you are rendering it to Windows media or Mpeg 2 for DVD, you might want to check that you have the right shape pixel (IE square) or Aspect ratio (IE 4:3 or 2.21). You find these on the video tab in the render as s custom template.
    Dan
  • Timothy Duncan
    May 13, 2005 at 1:50 pm
    So you shot HDV as 4:3? Or you want to pan/scan the HDV to 4:3?
    If you want to pan/scan to 4:3 do this:
    Apply Pan/Crop.
    Under Source:
    set “Maintain Aspect ration” to “No”
    set “Stretch to fill frame” to “Yes”
    Now — right click with the mouse directly over the video image inside pan/crop and choose “Match Output Aspect”. This will simply crop the left and right sides of the HDV footage to perfectly fit your project size.
    td
  • Jeremy Rochefort
    May 13, 2005 at 4:01 pm
    hi all
    I feel like a right real twit
    The answer was staring me in the face and I didn’t see it. Besides selecting to Not maintain the aspect ratio, there is also a selection for 4:3 in the pulldown which correctly displays the frames.
    Many thanks all
    Jeremy
