Activity › Forums › Adobe After Effects › Simple question about keyframing
  • Simple question about keyframing
    Posted by Mike Mackenzie on May 21, 2005 at 9:17 pm
    Hi everyone
    I used to know how to do this years ago, but things have changed a bit since I last did it. I know this is embarrassingly simple:
    How do I get a layer to adjust it’s brightness based on the audio waveform of another layer? That is, brighter when louder.
    Mike Clasby replied 21 years, 4 months ago 2 Members · 1 Reply
  • Mike Clasby
    May 22, 2005 at 7:23 am
    Adobe has lots of tuts, two of which should help.
    https://studio.adobe.com/us/tips/main.jsp
    Choose, After Effects from the drop down.
    Then you need to log on, or register (its easy).
    Will get you this tutorial:
    “Using music to animate layers”
    This tell you how to convert audio to keyframes and with an expression tie audio to scale (or anything else you want)and how to adjust it to make it work the way you want (can be the hard part if you don’t know what to do).
    Another tut on one of the 7 Adobe tut pages:
    “Go from dark to bright (or bright to dark) by animating the tint effect in Adobe After Effects 6.0.”
    Maybe this will help for brightness, tying audio to % tint for brightness, or use another effect for brightness. Levels maybe?
