Activity Forums Adobe After Effects Expressions Simple Position Expression
  • Simple Position Expression
    Posted by Justin Vaillancourt on January 18, 2010 at 4:55 pm
    Hi, I’m sure this is pretty basic, but I searched for it and couldn’t find anything.
    I want to move the position of a layer in either x or y by a defined amount of pixels per second OR
    Have the layer move on the x or y by a defined amount of pixels over the length of the comp
    Any help is much appreciated!
    Thank you
    Justin
    Justin Vaillancourt replied 16 years, 7 months ago 2 Members · 2 Replies
  • Dan Ebberts
    January 18, 2010 at 5:13 pm
    Here’s an expression that will move in the x and/or y direction based on pixel speeds you specify in the first two lines (it’s set up for the positive x direction, but just edit the speeds for different results):
    xSpeed = 100; // pixels per second
    ySpeed = 0;
    t = time – inPoint;
    value + [xSpeed,ySpeed]*t;
    This version is similar, but the first two parameters specify total pixels over the duration of the comp.
    x = 500; // total pixels over comp
    y = 0;
    xSpeed = x/thisComp.duration;
    ySpeed = y/thisComp.duration;
    t = time – inPoint;
    Dan
  • Justin Vaillancourt
    January 18, 2010 at 5:17 pm
    Thank you Dan, you’re the best!
