Activity Forums Adobe After Effects Simple outline
  • Simple outline
    Posted by Nick Cochran on November 6, 2005 at 2:24 am
    Hi, guys. I’ve brought in an alpha silhouette from another program and I’m trying to figure out how to run an outline around the entire object like you might see in a cartoon (either black or white outline). I thought Render -> Stroke would work, but it seems that is merely for masks.
    Any ideas?
    Nick
    Nick Cochran replied 20 years, 10 months ago 3 Members · 3 Replies
  • Serge Hamad
    November 6, 2005 at 2:38 am
    Try: Layer>Auto-Trace then apply your stroke.
    Salut.
    Serge
  • Deathwolf
    November 6, 2005 at 2:57 am
    using a glow with the correct parametres will produce a stroke too if you dont wanna use a mask, else there was a plugin for puffin lounge i think, called border patrol.
    Other than that you can also try duplicating the layer, blur it from an amount equal to your outline radius, boost up alpha levels, and set a tint to the color you want, and then have this layer behind the original one, a bit dirty but works pretty well.(it’s basically what glows does, but allows for more tweaking)
  • Nick Cochran
    November 6, 2005 at 5:32 am
    Thanks a lot, guys. The mask method had some issues and the blur + alpha levels was familiar to me from PS, so I tried it and it works well. Thanks!
