Activity › Forums › Maxon Cinema 4D › Simple Motor / Connector / Pendulum issue
  • Simple Motor / Connector / Pendulum issue
    Posted by Jay Ingles on September 12, 2012 at 4:49 pm
    I’ve created a simple model as an example of an issue i’m having problems with in a larger project.
    I’ve got a couple questions:
    1. How do i set this up so that the pendulum cylinder is attached to the rope and motor? (see image1)
    2. How would i create this if the “rope” is required to be a non-elastic soft body? (see image 2).
    I’m new to connectors/motors so thanks in advance and hope this is a simple resolve.
    R13 File: pendulumexample.zip
    Image1:
    Image2:
    Jay Ingles replied 14 years ago 2 Members · 2 Replies
  • Adam Trachtenberg
    September 12, 2012 at 8:03 pm
    For No. 1, I think the key thing is that the various parts aren’t being seen by the dynamics system because you don’t have a connector sticking peg1 to the wheel. Because of that, the first hinge connector isn’t following the peg. So I think you have to give the peg it’s own dynamics tag and then use a fixed connector to pin it to the wheel. For best results I think you also should convert the primitives to polygon objects so you can use point selections to establish the connecting points.
    Here’s my play with it: 4648_pendulumamt.c4d.zip
    As you can see, I added some Hair/spline dynamics to fake a string look, but unfortunately that doesn’t play with the regular dynamics system. You may be able to use soft dynamics for that, but I suspect it would be quite tricky.
  • Jay Ingles
    September 17, 2012 at 8:59 pm
    Sorry for the slow response, but thanks Adam for taking a look at it! I will open up your project file this week and hopefully it will shed some light on things.
    Look forward to seeing what you’ve done.
    Thanks again.
