Activity Forums Adobe After Effects simple L.E.D Display Rendering Question?
  • simple L.E.D Display Rendering Question?
    Posted by Sebastian Rivera on April 24, 2013 at 4:50 pm
    HI,
    I am not very familiar with L.E.D displays so pardon my newbiness.
    I was told that the Resolution of the L.E.D Screen is 80 by 128.
    Eighty lines, one twenty eight columns.
    I usually work with AE – So should I make a Comp that is 80 by 128 and render out for delivery?
    with that resolution
    or should I render a 320 by 240 video with a comp inside that is 80 by 128?
    Thanks for the help
    Sebastian Rivera replied 13 years, 4 months ago 2 Members · 2 Replies
  • Walter Soyka
    April 24, 2013 at 5:08 pm
    You need to get specs for delivery from the technicians responsible for the display.
    There are a lot of possible variables here, often more related to the playback device than the display itself, so we can’t accurately answer the question for you.
    I will add that the comp you work in and the output you deliver need not always match. You can work in a design space that’s separate from the actual display space when that’s advantageous. I do this often myself.
    Walter Soyka
  • Sebastian Rivera
    April 24, 2013 at 5:21 pm
    Thanks Walter! Your help is greatly appreciated.
