Activity › Forums › Creative Community Conversations › Simple keyframing
Simple keyframing
Posted by Tom Sefton on August 22, 2017 at 10:16 amGood god, how frustrating is key framing in FCPX. Just simple audio fade in and outs, leave the playhead at the precise point you want it, click to add a keyframe, and it jumps 3 seconds down the file. WHY???!!!
Co-owner at Pollen Studio
http://www.pollenstudio.co.ukBill Davis replied 9 years ago 5 Members · 14 Replies -
Scott Witthaus
August 22, 2017 at 10:39 am[Tom Sefton] “Good god, how frustrating is key framing in FCPX. Just simple audio fade in and outs, leave the playhead at the precise point you want it, click to add a keyframe, and it jumps 3 seconds down the file.”
Interesting, as I literally just did what you described without any issue. Tried multiple times and it simply did what I wanted. Of course I was zoomed in and had the clip height pretty big.
Scott Witthaus
Owner, 1708 Inc./Editorial
Managing Partner, Low Country Creative LLC
Professor, VCU Brandcenter -
Tom Sefton
August 22, 2017 at 10:43 amReally odd – its occurring at random but mostly when I’m not zoomed in too close.
http://www.pollenstudio.co.uk -
Scott Witthaus
August 22, 2017 at 2:26 pmIf you turned the Skimmer off, does that change anything?
Scott Witthaus
Tom Sefton
August 22, 2017 at 3:19 pmAlready have the skimmer turned off. The only way to stop it, is to click into the audio panel, manually move one frame back and forth with the arrow keys and click to add a keyframe. If I stop the playhead and then add one it appears in totally the wrong place. Weird bug and making a long job, very frustrating.
Scott Witthaus
August 22, 2017 at 4:02 pmOK, will try on a different system now. Delete prefs, etc?
Scott Witthaus
Scott Witthaus
August 22, 2017 at 4:05 pmOK, just tried on my MacPro system and everything worked fine. This morning I used a track pad and the macPro was using a USB-wired mouse. Still cannot reproduce what you are seeing. Which of course makes it more frustrating for you.
Scott Witthaus
Tom Sefton
August 22, 2017 at 7:37 pmDeeply frustrating. New Mac Pro here as well.
Bret Williams
August 23, 2017 at 1:01 amWhy aren’t you using the fade handles or the hot keys to apply fade handles? KEy framing fades seems rather laborious, plus adjusting later isn’t as simple.
_______________________________________________________________________
https://BretFX.com FCP X Plugins & Templates for Editors & Motion Graphics Artists -
Tom Sefton
August 23, 2017 at 7:42 amHaving to cut in and out of dialogue in some documentary footage so sometimes a snippet is needed and then audio needing to be faded back out immediately. The error seems to come when trying to add directly after stopping the play head using spacebar. If I stop with spacebar and then manually move one frame back or forth with the arrow keys it works ok.
Scott Witthaus
August 23, 2017 at 3:44 pm[Tom Sefton] ” The error seems to come when trying to add directly after stopping the play head using spacebar. “
Tried this too to see if I can duplicate what you are seeing with no luck. So, you hit the space bar to stop the playhead and option-click to set a keyframe and it jumps? Assuming that is the case, I cannot make that happen, with magnetism on or off.
Scott Witthaus
