Activity Forums Adobe After Effects simple fields question
  • simple fields question
    Posted by –bez–bez–bez– on November 12, 2006 at 8:34 pm
    i have made an edit and it is completely progressive footage. if i encode it onto dvd with interlaced footage. would there be any visual loss of quality or artifacting. the dvd will most likley be encoded lower fields first.
    i have already encoded the progressive edit to dvd lower field first and that was fine. but what if there are a mixture of edits, some progressive some interlaced?
    cheers
    –bez–bez–bez– replied 19 years, 10 months ago 2 Members · 2 Replies
  • Mylenium
    November 13, 2006 at 6:25 am
    Well, you’ll certainly see some differences, but it should not pose any problems. Obviously the right settings/ interporetation for the interlaced footage is of key importance. I wouldn’t worry about the progressive stuff. Either the edit suite takes care to duplicate the frames and derive frames from it or your exporter/converter does.
    Mylenium
    [Pour Myl
  • --Bez--Bez--Bez-- Create COW Profile Image
    –bez–bez–bez–
    November 13, 2006 at 11:10 am
    thanx
