Activity › Forums › Adobe After Effects Expressions › Simple Expression Error, why ??
  • Simple Expression Error, why ??
    Posted by Christopher Rotter on August 13, 2010 at 12:46 pm
    I’m trying to test some expression syntax out and why does After Effects throw me back this error for this expression?
    var blue circle=thisComp.layer("BlueCircle").transform.rotation
    Is there a way to make the font of the expression window larger, in After Effects CS3 ?
    Christopher Rotter replied 16 years, 1 month ago 2 Members · 9 Replies
  • 9 Replies
  • Dan Ebberts
    August 13, 2010 at 2:04 pm
    A variable name can’t have a space in it. Try it this way:
    var blueCircle = thisComp.layer(“BlueCircle”).transform.rotation
    As far as I know there’s no way to change the font size in the expression editor.
    Dan
  • Christopher Rotter
    August 14, 2010 at 3:25 pm
    I want to assign a variable on the Red Circle for the Blue Circle and removing the space continues After Effects to fire back an error:
    That error is:
    After Effects warning: Undefined value used in expression. Could be an out of range array subscript ?
    Error occurred a line 0.
    Comp: ‘Comp 1’
    Layer 2: (‘Red Circle’)
    Property: ‘Position’
    var bluecircle=thisComp.layer("BlueCircle").transform.rotation
  • Dan Ebberts
    August 14, 2010 at 4:07 pm
    Either of these seem to work:
    var bluecircle = thisComp.layer(“BlueCircle”).transform.rotation;
    bluecircle
    Or,
    Dan
    August 14, 2010 at 4:34 pm
    It’s not working, same error.
  • Dan Ebberts
    August 14, 2010 at 4:43 pm
    Well, I’m stumped. Both versions that I posted work for me, while the version you posted generates the error you described. Apparently you can’t end an expression with a var declaration (I guess I’d never tried it before) but if the versions I posted (which don’t do that) generate the same error for you, I have no idea what’s going on.
    Dan
    August 14, 2010 at 5:19 pm
    If something as simple as that, doesn’t work I’m not going to try anything else. I wanted to stay with CS3 Maybe I should scratch things together and upgrade.
    August 16, 2010 at 12:39 am
    I got the expression to work, it is quite sensitive it more so then the JavaScript language its self. I’m going to have to do some more practices so I know what arrangement the syntax has to be in.
  • Dan Ebberts
    August 16, 2010 at 1:51 am
    I’m really curious – what did you have to do to get it to work?
    Dan
    August 16, 2010 at 12:22 pm
    I thought I got it to work. Argh!
