Activity Forums VEGAS Pro Simple cut and paste
  • Simple cut and paste
    Posted by Albert Salmi on July 22, 2008 at 9:27 pm
    A cut and paste is supposed to be very simple. Here’s what I’m doing. I “Remove from group” my audio file. I want to select a short few words or part of the frame and cut it out from the audio track (only one track, no other). I can’t figure this out. Normally, you just hold your left mouse button and slide the mouse over what you want to cut, paste, copy, whatever…. but it doesn’t work with Sony Vegas. Can someone tell me how this is done? Thanks a lot.
    Albert Salmi replied 18 years, 1 month ago 1 Member · 1 Reply
  • Albert Salmi
    July 22, 2008 at 11:38 pm
    Never mind. I finally figured it out. It threw me when everything is selected when dragging. As long as your track is selected when you drag, only that data gets cut, copied or pasted.
