  • Posted by Rony Kimball on August 14, 2008 at 4:00 pm
    I just took over maintenance on a simple html website and the client wants the song he has playing on his home page to play continuously as you navigate the site. Is there a simple code based way to pull this off or will it have to load from each individual page?
    Curtis Thompson replied 18 years, 1 month ago 2 Members · 1 Reply
  • Curtis Thompson
    August 14, 2008 at 4:36 pm
    hello…
    ooh – to have it continually playing as a user navigates around, you have to have either flash doing the entire site or frames (so a hidden frame has the song and the site is in another frame – then as you navigate around the site in the one frame, the other frame plays the song…
    i can’t say that, however, w/o noting that frames are typically considered a no-no:
    https://www.google.com/search?q=html+frames+bad
    and i’m also not so sure that you want music – it’s also sort of considered impolite to do to users, but i’ll leave that up to you and your client… 🙂
    hope that helps!
    sitruc
