Activity › Forums › Adobe Premiere Pro › Silent Movie look with Adobe Premiere Pro?
Posted by Chris Lupetti on June 23, 2007 at 11:25 pmHello,
Can I get the silent movie look in Adobe Premiere?
Are there any tutorials on line that teach how to do this?
ThanksShacky replied 19 years, 2 months ago 6 Members · 5 Replies -
Harm Millaard
June 24, 2007 at 11:09 amHow does a silent movie look, apart from turning off the sound?
Tim Kolb
June 24, 2007 at 1:41 pmExactly.
Other than going monochrome and no sound, what do you notice about silent movies?
Typically the speed isn’t consistent as the film cameras were much cruder back then…the highlights tend to be a little blown out in many of the clips we see today, though whether that was the case when the film was actually shot is a different story. Contrast was the name f the game…backgrounds tended to be dark as the lighting necessary to get an image was substantial and if it was shot on a soundstage, the main characters seemed like they were the emphasis light-wise in many cases.
There’s no plugin that does this AFAIK. However, the effects generated by the most observant of us tend to surpass what you can do “out of a can” anyway.
TimK,
Director,
Kolb Productions,Creative Cow Host,
Author/Trainer
http://www.focalpress.com
http://www.classondemand.net -
Steven L. gotz
June 24, 2007 at 3:17 pmThere was also the occasional bright flashes (one frame perhaps), and posterized time helps with that stuttery look. Maybe even add a touch of sepia tone to the monochrome footage.
Steven
Nickhodemus
June 25, 2007 at 4:56 pmI would use B/W combined with Magic Bullet misfire / funk controls
You can get some warped footage looks.
Media Manipulator
Shacky
July 4, 2007 at 11:02 pmI have just started creating a similar project, and found that a good effect is to use a number of keyframes to change the ‘Fast Blur’ blurriness settings from zero to around 10-20 and then back again.
Combining this with changing the zoom level of your footage and/or intertitles by using keyframes on concurrent frames from 100% to 99.5%, then 100.5%, then back to 100%.
This will give the impression of the traditional ‘jumpy’ look that goes slightly in and out of focus every now and then.
using the Sepia overlay and altering the contrast settings, as well as possibly adding some ‘dust and scratches’ should give you that authentic early 1900’s Charlie Chaplin/Buster Keaton Silent Movie effect.
