Activity Forums Field Production Signal adapter / conversion at start or end of cable run?
  • Signal adapter / conversion at start or end of cable run?
    Posted by Jason Twite on August 12, 2013 at 7:59 pm
    Workflow:
    Canon XH AI output via HD Component –> BMD Analog to SDI mini converter –> input into switcher via HD-SDI.
    Which is the best practice?
    A) Have the mini converter right at the camera to go from component out and then make a longer run (100′ – 250′) of SDI cable to the switcher.
    B) Have the mini converter near the switcher and have component cables do the longer run?
    Trying to figure out whether I need to buy more component or SDI cables.
    Jason Twite replied 13 years ago 1 Member · 0 Replies
  • 0 Replies
