Activity Forums Apple Final Cut Pro Legacy Shuttling is Muted
  • Shuttling is Muted
    Posted by Matthew Cohn on October 28, 2008 at 10:20 pm
    I accidentally muted audio when I shuttle fast-forward and backward. I’m not sure how I did this, or how to turn the volume back on (audio is not muted when playing at normal speed). Could someone explain to me how this function works? Thank you.
    Francis Hughes replied 17 years, 10 months ago 2 Members · 5 Replies
  • Francis Hughes
    October 28, 2008 at 10:50 pm
    Do you mean scrubbing? If so shift+S
  • Matthew Cohn
    October 28, 2008 at 11:26 pm
    As far as I know, it’s shuttling, using the L and J keys to move fast-forward and backward through a clip. If this is also referred to as scrubbing, then yes, that is what I mean. If not, might the same solution apply?
  • Francis Hughes
    October 29, 2008 at 12:15 am
    it is the same thing basically, like when you use the arrow keys to jump frames you can hear the audio as well yea? If so that is shift+s enables and do the same again disables
  • Matthew Cohn
    October 29, 2008 at 1:38 pm
    That resolved the problem!
  • Francis Hughes
    October 29, 2008 at 3:25 pm
    Happy scrubbing!
