Activity › Forums › Avid Media Composer › shuttle problems in Avid Xpress Pro
  • shuttle problems in Avid Xpress Pro
    Posted by Angela Borg on May 29, 2007 at 3:27 am
    Hi, I am new to Avid and am trying to shuttle through my footage to quickly make my in and out points. Everytime I fast forward or rewind using JKL on my keyboard while in the capture tool, it then makes my footage play slowly. I stop shuttling and then when I play the master tape footage again it is not playing in real time, but playing at a slower jittery speed. Is there a preference I have to change, bc without being able to shuttle through my footage it will be pointless to use Avid to capture. Thanks in advance for your help.
    Angela Borg replied 19 years, 4 months ago 2 Members · 2 Replies
  • Chaz Shukat
    May 29, 2007 at 2:09 pm
    I don’t have a definitive answer for you, but I have the same problem on my Xpress Pro, and I don’t use the JKL keys, I use the buttons on the capture tool. Seeing your post made me wonder why I have never posted about it myself. I think it’s because I capture from a Sony DSR-11 deck, which is their bottom of the line deck and is not really built for shuttling. Maybe it’s a limitation of firewire. What are you using to capture from?
    Chaz S.
  • Angela Borg
    May 29, 2007 at 2:37 pm
    I am using an old Sony deck (GV-D300) as well but I know that it is not due to that because I use that same deck with FCP and shuttling is fine. This shuttle problem even occurs when I try using my camera as a deck. I am using firewire which is also what I use for FCP. I just don’t understand why this same meathod which works so perfectly for me on FCP is so bad on avid.
