Activity › Forums › Adobe After Effects › Shuffling the same image onto the screen repeatedly?
  • Shuffling the same image onto the screen repeatedly?
    Posted by Matt Sonberg on March 17, 2010 at 2:31 pm
    I saw this once before on something where the same image keeps getting shuffled in, say from the left side repeatedly at a random, fast pace.
    How could I go about setting this up so that I can do it with many times over and not have to set up all the position keyframes manually?
    Matthew Woods replied 16 years, 6 months ago 3 Members · 3 Replies
  • Todd Kopriva
    March 17, 2010 at 3:10 pm
    If I understand what you’re asking for, I think that the Offset effect will do what you want.
    putting the ‘T’ back in ‘RTFM’ : After Effects Help on the Web
    If a page of After Effects Help answers your question, please consider rating it. If you have a tip, technique, or link to share—or if there is something that you’d like to see added or improved—please leave a comment.
  • Matt Sonberg
    March 17, 2010 at 3:25 pm
    That’s not quite what I’m looking for.
    I want picture one to slide in from the side.
    Then a duplicate of pic1 to slide in from the same side maybe 3 frames later, then again and again and again, but all at a random rate fluxuating between say 3 and 6 frames each.
    So that you’d be “stacking” the same image on top of itself creating a bit of a strobe look I guess.
    Matt Sonberg
  • Matthew Woods
    March 17, 2010 at 3:46 pm
    Its a 3rd party solution, but Trapcode Echospace might work for you:
    https://www.redgiantsoftware.com/products/all/trapcode-echospace/
    I got it bundled with the Trapcode suite when we needed trapcode form and particular, and its turned out to be a really handy plugin when I need to do things like this.
