Activity Forums VEGAS Pro Shuddering motion
  • Shuddering motion
    Posted by Colin Oddy on October 18, 2009 at 9:48 pm
    Im rendering my finished Movie Studio 9 file to AVI Pal and in doing that the AVI file suffers an attack of shuddering image during camera pan or subject movement sequences.
    Difficult to explain the effect but its like each frame slots into place sideways during the movement sequence – its fine when theres not much movement.
    Anyone know what causes this? How it can be fixed? Is it an editing or rendering setting Ive overlooked? or is it a low resolution original camera image perhaps? Any ideas please? Cheers.
    Colin
    Colin Oddy replied 16 years, 11 months ago 3 Members · 8 Replies
  • 8 Replies
  • Jeremy Rasnic
    October 18, 2009 at 11:30 pm
    Does the camera you are using have a CMOS sensore instead of a CCD? If so, this phenomenon is called rolling shutter. Technology is getting better at correcting this issue, but in some of the first HD cameras and CMOS sensor cameras (camcorders) this issue is pervasive.
    Here is a link concerning the issue.
    j razz
    https://www.jrazzcreations.com
  • Colin Oddy
    October 18, 2009 at 11:45 pm
    Hey Jeremy thank you for that lead – I wondered if it was something from the camera source. On checking the camera its a JVC GR-D230AA 1.33 megapixel(1/4″) CCD. Not very high resolution but it does say CCD. 🙁
    Colin
  • Jeremy Rasnic
    October 19, 2009 at 3:09 pm
    Can you post a screen shot of what it is doing? Could it be that the field order is wrong? You know, Lower Field First instead of Upper Field First?
    j razz
  • Or Tal
    October 19, 2009 at 6:12 pm
    I suffer from those problems on a regular basis
    Few things to try:
    1. It’s a bit strange but try to restart computer before you render. and don’t use the computer while rendering. (give it a try and see, perhaps some jitter may occur otherwise)
    2. try make an interlace test. render a section with: 1. progressive scan, 2. upper field first, 3. lower field first. and compare.
    (project preferences)
    3. I tend to believe that motion in vegas, generally speaking, is problematic. I hope I’m wrong, but It doesn’t looks high quality motion in my opinion. especially slow motion.
    4. if you have “ghosts” in events of slow motion try also:
    event properties
    reduce interlace flicker (check box)
    resample: none
    good luck
    Or Tal
    Or Tal
  • Colin Oddy
    October 19, 2009 at 11:24 pm
    ah ha Jeremy thank you. 🙂
    yes it was lower field first. ill change that.
    also.. is interleave every .250 ok? or should it be set as interleave every frame?
    thanks heaps.
    Colin
  • Colin Oddy
    October 19, 2009 at 11:31 pm
    Thank you Or Tal – Im very pleased to hear suggestions and thank you for taking the time to respond. 🙂
    Ill give it a try and let you know.
    Cheers
    Colin
  • Or Tal
    October 19, 2009 at 11:48 pm
    You’re welcome 🙂
    Or Tal
  • Colin Oddy
    October 21, 2009 at 2:30 am
    YESSSSSSSSSSSSSS
    thank you to veryone who offered assistance.
    The shuddering was overcome by selecting Upperfield First in custom rendering. Ive defaulted it and Im happy as!!!!!
    many thanks
    Colin
